compression #'s for a 1987 johnson 150
bajabassboat
I looked at a 1987 Johnson 150 and all the cylinders read 81-85. The motor was not started for 6 months so are these bad #'s ? Would running the motor cause the compression #'s to get highter? Is this 87 johnson 150 worth spending $2000 on installed? Or should I have someone rebuild my 83 evinrude 115 for $2000. Thanks!
Benny1963
Re: compression #'s for a 1987 johnson 150
the numbers are a tad low .but they are fairly equal a decarb and running it may bring those numbers up.what kind of numbers are you getting on
your 115
bennyb
tashasdaddy
i think with those numbers i would rebuild the 83, at least you will know what you have. paying 2,000 for the 87 may be a rebuild next week. the #'s are too low for me.
JB
I would confirm those numbers with a different guage. I find it hard to believe that 6 cylinders would all go "bad" the same amount at the same time.
Even if a different guage confirms PSI in the 80-85 range I wouldn't schedule a rebuild until after water testing the engine and getting poor performance.
I think the engine is probably healthy.
