Compression tester question ?
Gulf Boater
Need to pick up a compression tester to test my 125. Do I need a special kind due to the surface area plugs. I have read that most people use automotive testers but want to make sure I'm not going to damage the top of the piston
pnwboat
Re: Compression tester question ?
No special compression tester required. Any standard compression tester will work. The adapters that screw into the spark plug holes only have about a half inch of threads so they don't stick out far enough to come close to the piston.
Gulf Boater
Thanks off to Harbour freight
PS
Do you know what size the thread is for 125 force want to make sure it comes with rt adapter
Found it 14mm thread
jerryjerry05
Any tester should work.
Just make sure that you remove all the plugs to do the test.
Then ground out the plug wires or leads.
Some say just unhook the kill switch.Sometimes that works.Sometimes it doesn't.
PS
I would get something higher quality than Harbor Freight.
Gulf Boater
Wasn't really looking to drop $100 + on a tester I will only use a couple times.
However marinas test was 150,30,80,25
My readings were 130,129,130,130
So now I don't know what to think:confused:
pnwboat
Some of the auto parts store will loan you specialty tools for a small refundable deposit. I believe AutoZone will do this. Might check them out.
carholme
I wouldn't worry about the tester you got at Harbour Freight. If you want to test it yourself, hook it up to an air compressor or a spare tire after checking the tire pressure. Then just use the compression tester as a tire gauge and see what it reads in comparison to the known pressure in the tire. Telling some marinas to do a compression test on your engine is like opening your wallet and letting them take what they want.
Gerry
auchandler1
I bought mine at autozone for like $10 and it works great.
sphelps
I got a H/F one on sale. Took plugs out , left wires loose , did test , 119,118,119. Did I do that wrong? Not sure about grounding out plugs?
Gulf Boater
How does one go about grounding the wires ? Also where is the kill switch located on force 120 ?
jerryjerry05
I use a #10 wire in a 3-4 wire (I call it my little squid)grounding harness.
I use a #4 copper connector,3/4 pieces of #10 wire about 15" long.
Strip all three about an inch and install in the #4 connector.
Strip about 3/4inch from the other end and solder them so the end becomes hard.
There you have a grounding lug for either a 3 or 4 cylinder.
My twins are 3 cyl so that's all I need.
Compression results: A cheap tester is all you need.
The results are what you need.
All cylinders should read the same.Your tester might read different than mine.
Mine might read 150 when yours reads 125 But if all 3 or 4 read the same that means the cylinders are ok.
Your looking for the same readings across all cylinders. One show different thats what your looking for.
