HotTommy
- Mar 15, 2013
- 1,025
I am putting my 1993 Force 150 outboard back together after replacing the pistons. It is off the boat. I'd like to check the compression by hot wiring the starter to a battery to turn it over. I understand that I need to ground the spark plug wires to do this test on the boat using the key because it engages the ignition system. If I hot wire the starter only, do I still need to ground the plug wires? I'm uncertain because the spinning flywheel will generate current with the rotor and stator. .. Anyone know the for sure answer?
