Compression Testing Problem
GeorgiaMan
hello i got a 05 50 hp mercury outbourd , I am wanting to do a compression test on it and I am needing to know what size adaptor do I need for the mercury spark plug holes..I am thinking a 12 mm or 14 mm adaptor can anyone let me know thanks ....
aussieflash
Re: Compression Testing Problem
Most testers come with size adaptors.Stick it in and see.
86 century
Ensign
The cheep one from autozone has all the adapters I have ever needed.
catfishr1
Yep ;I too use the cheap one frm Az & always have adapter needed. Welcome aboard GM. Make sure you ground spk plg leeds before the test.
jerryjerry05
Most testers are ready to use on all outboards right out of the box.
