Putzaroni1
- Oct 20, 2012
- 108
I wanted to clarify this one as I see mostly larger electric start motor instructions on this forum and elsewhere.
tashasdaddy has great instructions in the Top Secret file but again it's for larger motors. Please have a look at these instructions for a smaller non-electric start motor and let me know if I'm on track or they need any adjustment.
If these are good, I will try making a video of this procedure as there are lots of questions about this including mine ;-)
1. Start engine and warm it up (not completely necessary but will provide higher compression numbers)
2. Remove all spark plugs and disconnect fuel line
4. Pull the emergency kill switch on rope pull start motors if there is one. If not be sure to ground the spark plug wires to the block. To do this, put the plugs back in the spark plug wires and attached a grounding wire to the spark plug and then ground it to the engine block. Do this for all plugs. This will insure that any current coming out of the coils will go to ground rather than potentially fry something back in the ignition
5. Screw guage into #1.
6. Pull start engine 5 or 6 times watching the compression gauge to confirm the needle is no longer moving up
7. Repeat steps 5 & 6 for all cylinders.
All psi readings should be within a 10-15% span.
