compression
lmdickens
i have 1969 mercury 500 50hp motor need to know what the compression should be thanks.
Overnighter20
Re: compression
Equal across all cyclinders is the most important thing, within 10% is acceptable. I never was able to find actual specs for my Johnson, but all 6 range from 114 to 118 lbs so I think she's still in good shape.
Aqualift
Re: compression
I have a 65 and a 67 Merc 500. My 67 has 105-110 across all four. My 65 averages around 100 on all four. Still plenty of power. These compression readings are at 6500 feet. You flatlanders will have higher readings.
lmdickens
Re: compression
thank you 3 are at 80 pounda 1at 85 pounds i thought it was low but it runs pretty good anyway
lindy46
Re: compression
Are you hand-pulling it or cranking it with the starter? Makes a big difference.
JB
Re: compression
Different people, using different guages, under different conditions and using different technique may get as much as a 50psi difference on the same engine.
Don't worry about psi. Look for all cylinders to be within a 10% range.
Overnighter20
Re: compression
6500 FT?
Is that a boat or a snow ski? LOL
