Re: Compression
What is a Tige V-drive? and how would that relate to 'broken' compression in a motor? Compression, in motors, is not usually referred to as broken. When a compression test is performed, the results are expressed as X psi in # Y cylinder. I don't think you have given enough information for a responsible answer to be given.
