waterboy84
- Nov 25, 2015
- 98
I did a compression test on my 120hp force just to make sure compression is ok.
Cyl 1=155
Cyl 2=170
Cyl 3=170
Cyl 4=165
Do these number look ok for compression.
I personally feel like those compression numbers are high. However im not sure thats why im posting this to ask.
I did the compression test 2 different was.
I did both compression on a cold motor test.
Not cold as in outside temperature cold. I mean cold as in not running motor cold.
However i first did the test by removing one plug at a time.
Then the next day i did another test by removing all the plugs.
Compression numbers didnt change. They were the same readings .
Is the compression ok on my motor. Thanks for the info
Cyl 1=155
Cyl 2=170
Cyl 3=170
Cyl 4=165
