Computer Overheating
Reel Poor
I've been having problems with my computer overheating when running at high speeds for more that an hour. Any suggestions would be appreciated. Here is a pic of the computer im running.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />.<br />
<br /><br /> :D :D :D :D :D
PAkev
Re: Computer Overheating
Have you checked the coolant?
beezee28
Master Chief Petty Officer
The fuel that you are using is too high in Octane :D :D :D What is why it is overheating :p :D
LubeDude
At least Im the first to suggest this.<br /><br /> :rolleyes: Running a synthetic oil will make it run cooler! :rolleyes:
roscoe
First off, you are running fuel into your oil cooler. Very dangerous to be using fuel as a coolant.<br /><br />Overheat stems from the fact that there is no return coolant line from the motherboard, therefore no coolant flow.
Reel Poor
Thanks Roscoe....But this is the new "Dual Cool Fuel Control System". The return line is the one from the bottom. :D
PierBridge
Do you have any pictures from different angles.<br /><br />Have you presure checked the system.<br /><br />Then again maybe it's just an air bubble try bleeding it.....<br /><br />Them Pentiums have always run hot......
Boomyal
Did you solder the connections RP or crimp them? :p
Reel Poor
Boom all the conections are soldered. The only thing here crimped is my style. :D
jch7450
I think the timing is avanced to much :D
