Re: condensation inside boat
Slicksboy,<br /><br />Dunno where you're from, but you are probably in an area of high humidity, or big day/night temperature changes - right? <br /><br />Big minus with boats is that they often get close to water! So the boat easily gets covered in condensation with every change in day/night temperature.<br /><br />What you say about windows that are warm inside and cold outside is right - but condensation only forms on non-porous surfaces if airborne moisture is present inside the boat. Dry air, whether warm or cold, will not precipitate.<br /><br />Trouble is, by the time you see the droplets on your windows, your porous surfaces - bedding, cushions, etc - will already be damp because they are hygroscopic - that is, they attract airborne moisture.<br /><br />There ain't no cast-iron solution, but the way you've gone about it is spot on. Ventilation when the day is warm and dry also makes a big difference - and that's free.<br /><br />Ciao
