condensation? submersion?
ron51
Condensation ? Submersion ?
I let a friend park his 4.35mt Rush Jet Boat on my farm form July to December.
He parked it on an incline with the Bow lower than the drains at the stern allowing the boat to fill up with rain water until it reached the level of the drains (approximately one third full) there were no winter storage precautions taken-such as fogging the engine- etc , not even the battery was disconnected.
This jet boat has a 90 Hp. Mercury two stroke 3 cylinder horizontal in board engine.
The engine cover and the front hatch were closed during this time, so the only ventilation was through 3 drains 2 at the rear one between the **** pit and the bilge, ( this is where the water got in ) He took the boat to get serviced and the mechanic found water in all three carbys? water in the bottom cylinder with rings seized and rusted and water in the starter motor.
The mechanic told him that the engine must have been submerged, so now he is accusing people of taking his boat and sinking it.
I have two questions:
1 Would the conditions I have described cause the damage to the engine?
2 If the engine was submerged to the level to fill the starter motor, then wouldn?t
All the cylinders have water damage ( the starter motor is above the carbys? )
( Hopefully there is somebody out there who has first hand experience with this type of boat and either of these conditions ).
Re: condensation? submersion?
Ayuh,.... That would be My 1st guess....
You might have better luck in the Jet-Ski forum, as that's pretty much what it is,...
Tell you friend that things like this Happen when you don't take Care of your Toys....
Don S
That motor is an outboard powerhead mounted on a jet pump inside a boat. Moving to the Merc OB forum for better answers.
Alumarine
Mechanic was probably right, the motor was submerged - by rainwater - on land.
People who blame others for their own neglect are my favorite.
