Re: cone clutch big job????
They won't shift right with water in the gear lube. You need to get the milky oil out and new in and check it. You may have to flush out the milky oil.
I would also pressure check the drive when you get the propshaft seal replaced to make sure that is the only place it was leaking.
Did you ever pull the drive and check the bellows for water. That may be your problem for both engine and drive problems in your other posts.
Thank you for you quick reply.
The engine is going 100% thank good
I have never pulled the drive the belllows look spot on from what I can see of them.
I replaced the gear oil thinking it may be that but it did not change anything still the same when I put it back in the water. I changed the seal 2 year ago, this only starting happening in the past few week (sorry for the long post)
While I had it out of the water last time. I disconnected the shift cable and put it in manualy, while in reverse i could only turn the prop anti clock wise and would lock the other way... But when in forward it would turn but very hard and would eventuly lock....
Thanks Don in advance I'm driven mad with this thing
