surban21
- Sep 15, 2019
- 26
Preparing to replace strings, transom, deck, etc as they are completely rotted on my 1978 15' 6" Challenger Mark VI tri hull. I've been reading many rebuild projects on this site and specifically (of course) Friscoboater's rebuild. I've decided to use all polyresin with 1708 and csm, etc.
When it comes time to tab in the stringers, transom and what-not, I'm confused. Just about everything I've read said to layup with unwaxed polyresin, and on the last layer use waxed, otherwise the resin remains tacky due to it being exposed to oxygen (air). However, Frisco's rebuild was done entirely with unwaxed resin except for the top of his deck (I believe). At some point, I also read a post by Woodonglass where he stated he'd personally would not use a waxed final layer on any structural under the deck.
So I guess my question is, can polyresin actually be used without the top layer being waxed? And if so, does that weaken its final curing strength? I will also welcome any other thoughts regarding this.
Any thoughts or ideas about this would be very helpful. Thanks
