Cardsharkhere
- Nov 4, 2018
- 3
bought a I/O and started winterizing it. Drained all the lower casing oil (had some water in oil) Started refilling the oil (both screws out). All of a sudden the oil in the boat pressurized and the pressure was causing oil to come back through the pump. Take a closer look and the top screw hole has a white plug that was behind the upper screw. What is this white material has the consistency of chalk? This is a Midwest boat so I do not believe it is salt
