beckoning
- Dec 15, 2010
- 164
I have a 2-battery system with a PERKO switch. Using very heavy gauge battery cables, it is difficult to jam everything inside the little PERKO. How to connect 3 positive (RED) battery cables that will go to the same PERKO bolt connector so I'm just putting one cable onto the PERKO instead of cramming 3 onto the post? There must be some sort of connectors. Alternatively, I could bolt the 3 eyelets together and wrap the wad in heavy rubber insulation. Is there a danger in connecting 3 red cables to a 4-6" pigtail cable that attaches to the PERKO? Is there a risk of overheating the pigtail when I'm running on both batteries to charge them? BTW, I had a PERKO for 14 years on my prior boat, and it worked like a charm....thinner cables, fewer toys. Lots more amps flowing on this boat......4 electric riggers, Lowrance, Garmin GPS, radio. All powered by a 150hp Tammy.....I'm in heaven.
