Re: Connecting 2 fuel tanks,draw from both?
Not as easy as it sounds. If you have a problem in either tank or primer system like running out of gas are a leak, your stuck out with lots of gas but no way to use it. I use a three way valve and even then sun heats up one of the primer bulbs and occasionally causes vapor lock. I have thought about the solution for years, but have not implemented it yet. Two electric fuel pumps,one at each tank of the low pressure type would eliminate the primer bulbs and solve all our problems. Went so far as go to the auto store and locate two pumps and then decided I would do it another time.
