What do I need to connect a second deep cycle battery to my DV-16? It currently is set up with just one deep cycle battery connected to the trolling motor at the front of the boat. Would I need to purchase a different receptacle and wire that my trolling motor plugs into since I will be using two batteries? I don't have the wiring right in front of me, but I believe that there are only conncections for one battery back to the trolling motor receptacle. I would also like to add a battery selector switch so that I can choose which battery to run independent. The boat is wired as it came from the factory with just one deep cycle batter and a cranking battery. Thanks.
