I have a 2005 mercruiser 50 4 stroke efi. I am trying to find the correct prop for my pontoon, which does not have a tach. I tried using my multimeter on the tach setting, on the grey wire. that doesn’t seem to work. I also tried two different tachs from amazon, again using the grey wire. the numbers are of by over double, even when the tach is set for a 4 cylinder. I also tried using my timing light, that has a tach function, with the inductive pickup on cyl 1 spark plug wire. idle numbers looked good, but then as soon as i added throttle, the numbers were double what i’d expect. if i put the the timing light in the 2 stroke setting, idle was off(450), but the mid and high numbers looked and sounded correct(4800). I think i still need to go down in pitch, but want to make sure i’m reading the Rpm correctly. this engine I believe has cdi ignition, with a separate coil per cylinder, so i can’t see it having a waste spark system. any suggestions or thoughts? i’d love to hear them. thanks.
