Connecting wires to Ignition switch
Seeker
I am replacing a defective ignition switch on a 1977 Evinrude 85 HP outboard, Model #85799S and need to know which wire goes to each terminal on the switch. Wires are colored as follows: Red, Black, Purple, Purple/White, White, Yellow/Black. Switch terminals are designated for: Magneto Circuit, Choke, Ignition Circuit, Solenoid, Battery. The 6th terminal is not designated.
I tried replacing the wires on new switch in the sequence they were o
defective switch but it didn't work. Your knowledgeable help will be much appreciated.
