First off... GREAT SITE!<br /><br />I have a 1988 evinrude vro 150 about a week ago I noticed a very faint buzzing in the control box at high speeds progressively the alarm got louder and you could back out of the throttle (still on plane) and the alarm would quit. The alarm got to where it would stay on at anything over an idle. I have checked the temp sensors and thermostats but now the alarm goes off as soon as you rev up the motor even on a cold start. Now that is what the motor was doing until being the master mechanic that I am made it worse. I checked all of the fuel filters and fuel lines all were OK then I thought I would check the vacum switch so I took it off must have been a big mistake because I hooked it all back up and now as soon as you turn on the key the alarm comes on and stays on. I have heard how reliable the fuel pumps on the vro are so could it be the vacum switch itself? How do you check the vacum switch? Is there anyway to make the alarm turn off? If I go to a regular fuel pump and pre mix gas do I still need the vacum switch? Any help you can give would be greatly appreciated. Thanks.<br />Arkbuck
