I'm helping my son-in-law get his Mercruiser 3.0/Alpha One stern drive up to snuff. Over the winter we were unaware that water had gotten into the power trim system and by spring both trim cylinders were cracked wide open. The remainder of the system looks intact. I've taken the trim pump and motor assembly off for a good cleaning, but I'm not sure just how far down I should strip it to ensure a good cleaning. Is it even necessary to strip it? The pump appears to be working, and I was wondering if running some clean trim fluid through it into a waste container would be all that's necessary.
I'd welcome any thoughts on the issue.
Thanks
Thanks
