I have a 1992 740 carburated volvo penta. I'm having a problem with the fuel pump running continuously as long as the battery is switched on. I've replaced the fuel pump relay and the ignition switch, but the problem persists. Any thoughts? Thanks!
I attached the engine serial number.In most cases is one of the diodes which have shorted out. Do you have the serial number for the motor?
