Re: Continuity Kit?
Depends where it broke. If you can get to it with a small soldering iron, go to your local fastner distributor. There are shrink wrap connection insulators that have a silicone like substance in the layers of insualtion. They coast about a dollar for 6 inches of the stuff. Silp it on, slide it away for the heat of your soldering job and solder the wires together. Then slide the waterproof heatshrink over the repair and use a bic lighter or heat gun to heat the piece carefully and it will shrink around and seal the connection. I have done complete trailers that run winches with the stuff as they need to be hot while in the water to run the winch. Never had a failure. BTW, cable/electric companies use this type of connection sealer all the time in buried applications.
