Control Arm neutral lock worn, Does not lock sufficient.
aldwill49
The plastic stop for control arm is worn and no longer prevents movement of control arm from going into gear. Are there any replacement locking arms.
Re: Control Arm neutral lock worn, Does not lock sufficient.
Like to Help,.............<br /><br />Gotta have a Few Clues,..... As to Just What You're Working On...........
Bt Doctur
sound like the control box idle release button or the release in the handle itself.
aldwill49
I have a 86 18' Open bow Ebtide with 4.3L OMC. The throttle/forward/reverse control arm has a plastic inner sleeve that is force down by a spring in the top of the control arm. this flat plastic plate apparently is worn enough, that it does not prevent the shifting of the throttle/gears, without lifting the release under the control arm handle. <br /><br />I see no markings on the handle as to a model or time. Any ideas where I can get a replacement?
