LilRedNeckGirl
- Jan 25, 2010
- 184
On a 1970's era Johnson single lever control box, We are having issues . We had to take it apart to install a neutral safety switch. after reassembling it, when taken from neutral to forward, it works fine, @ shifts then throttles up. then i return it to neutral, and attempt to put it in reverse. It wont budge. wont shift or throttle, like its hitting a wall.
We have dis assembled it a few times, greased it, checked for broken teeth on the assembly, checked all cables, cable bushings and guide channels, checked the locking tab and release handle, and all seems fine, but without fail, when assembled, it might work once or twice then it freezes up. we take it back apart and look and all things are in place as when we assembled it.
We are planning the maiden voyage next month on the Chickahominy river after months of restoration and renovation on a 70's Glastron tri hull. This glitch has us stumped. to make matters worse, I cant find the service manual I bought.
Any advise?
Any advise?
