wildmaninal
- Jul 14, 2007
- 1,897
I am running into problems left and right on this motor and control box of mine. The type of control box I have is the style with the warm up lever, it is hooked to my '78 evinrude 85hp. I bought a ball to install on the spring in the control box. Obviously when I took the control box off of the other boat to install it on to my bass boat last year I lost that ball, well I just replaced it today.
Thinking that this ball would cure my problem I reassembled the control box and without the motor running I go to test the controls by putting it in forward gear and then bringing it back to neutral then try to put it in reverse and it will not go, it won't even make contact with the neutral switch to allow me to turn the motor over with the key.
I have had this control box apart several times already, and the same thing happens over and over. I have been able to reassemble the control box and then put it in reverse then to forward gear then back to neutral then the same thing occurs. I did adjust the shift cable just a little bit thinking this might cure the problem but it did not. I have also disconnected the shift cable from the motor to see what would happen, nothing changed. I have adjusted the tensioner nob and this did not help.
Any ideas?
Any ideas?
