control box
studders
hello, I have a 1989 Baja islander 190 3.0 mercruiser I/o. my control lever was a little tight so I made some adjustments on the cables and lubricated where it needed. The lever is better but I think it could be better. are you suppose to lubricate the control box or make any adjustments in there? if so can does anyone have a link or explain how? thanks for your time
Ayuh,.... I don't take 'em apart, unless absolutely necessary,.....
I do occasionally squirt some oil into the works from behind the panel it's mounted too,...
gm280
I honestly don't know about all control boxes, but the ones I have seen and used usually had nylon disks and rub points to help with their movement. But some quality grease or oil can't hurt with anything that moves... JMHO!
gddavid
First I would verify that your stiffness is coming from the controls themselves or from the cables, linkages or outdrive shift cable. Is it stiff when you are using the controls to apply throttle only (warm up mode where you press a button or pull the lever out to disengage the shifting) or while shifting and applying throttle? You can disconnect the cables at each end to track down where your friction is coming from.
In many cases the shift assembly feels stiff because the outdrive shifter cable needs to be replaced. This cable runs between the control connections near the top of the engine, through gimbal housing to the outdrive bell housing. There is a piece of hardware attaches to the inner cable and when it accumulates stiff grease, corrosion gunk it screws up the shifting. In my experience it should be changed out about every other (or every) bellows replacement.
