control cables
david_r
:redface::redface:eek:k yes know how to read a tape measure and yea i took it out and laid it on the ground is reads 11'5" tip to tip. no its not completly broke just the outside casing wires are broken.
:redface:am i not measuring it right?
:redface:is it not supposed to be measured tip to tip?
can anybody help me out please!!!:)
thanks for any help!
david_r
Re: control cables
:redface::redface:i felt so silly even asking i forgot to mention its a '79 johnson 115:redface::redface:
eli_lilly
Re: control cables
They don't have to be that precise, just go with a 12'.
tashasdaddy
Re: control cables
the black sheath should have a number stamp into it. that is the replacement #.
jay_merrill
Re: control cables
Also, if the cables are for an OMC motor, make sure you get the right ones. The cables for the older control boxes have bare wire ends, onto which you install the end fittings with set screws. The newer ones have the fittings already installed. While the fittings on the motor end are the same on the two types, the fittings on the control end are not, and won't work with boxes that require the bare wire type.
I believe that the last year that the bare wire end cables were used was 1978. Remember, however, that the issue is what year the control unit was made, not the motor. If in doubt as to what you have, just look at the cables you are replacing.
