Control/Drive Sync Issue
1999 Searay 180BR
Long story short... Boat runs fine except when control is moved to what would be the neutral position, the drive does not disengage.
Without squeezing the control lever lock I can apply slight pressure to the control lever in the "Reverse" direction and the drive will disengage.
Adjustment or replace cable?
1999 Sea Ray 180 BR/ Mercruiser 3.0- Alpha Drive
Ayuh,..... That's a Classic symptom of a draggin' sticky lower shift cable,.....
