Conversion
Bayliner2264
I have a 1996 Bayliner with 5.7 litre looking to convert from mechanical fuel pump to electric...any suggestions or has anybody else done this
Ayuh,..... Welcome Aboard,...... Is this a Mercruiser, OMC, or Volvo,..??..??
why?
a mechanical pump is just under $50. an electric pump, the relays, wiring and oil pressure switch will cost you over $100 and it wont last as long.
Rick Stephens
Must have the very very last 5.7L ever to roll off the foundry line with a mechanical port on it.
I'd stick with a mechanical given a choice.
most likely a left over 1995 motor (non-vortec)
Scott06
I'm assuming you have a newer replacement block that doesn't have a provision for a mechanical fuel pump?
you need to wire it up through a oil pressure switch. If you follow the merc wiring diagram you can see how to properly wire it up. The merc pumps are made by airtex which is available at a much lower cost. Just need the correct pump (low pressure for carb applications).
