the machinist
- May 7, 2002
- 711
I have a 1980 70hp Johnson that has a Outboard Jet unit installed, mounted on a 16' aluminum sled. I have removed the steering wheel / remote controls & have converted it to tiller steering by using a e-Bay purchased tiller off a newer 60hp motor.
Everything is fine, except now it pivots so easy that I would like to put friction on the pivot shaft. I see in the parts lists that the motors that were designed for tiller usage had adjustable friction on the shaft.
My question, have any of you torn a remote designed motor apart & installed a tiller friction "kit" in?
