converting 25 to 35hp
kovman
Has anyone converted a 1985 or newer 25hp into a 30 or 35 hp. Can it be done and if so what are the parts I'll have to mod, salvage or buy?
tashasdaddy
Re: converting 25 to 35hp
many. sell what you have, buy what you want.
bktheking
In other words , cost outweighs the benefit!
Whoopbass
There's been a couple threads here that say just a carb swap will work.
You can read this thread and decide for yourself.
http://forums.iboats.com/showthread.php?t=274566
I have a 1987 25hp and I don't think it can be done for that year. I had a 35hp carb and installed it and it wouldn't idle right unless the low speed adjustment was turned way out. I went to the evinrude parts website and compared my motor to earlier and later motors and for some reason that year was different then all the others.
I only tested it at home and it didn't seem right so I removed it. I did put that carb on a 78 25 Evinrude and it seemed ok. I had a jet pump on that motor and that was my first and only trip with it so I don't know if there were any gains. I sold the motor shortly after because it wasn't enough motor for my boat.
