Converting 30' pontoon from 2cycle to 4 cyl mercruiser
Westport
I went to a high school homecoming game/reunion and had a blast. I ran into my cousin who I had gone out on his pontoon boat last week and we did some talking about doing a river run next year. I have gone out with him and his family on the Wabash river, launching in at Vincennes In. I find out that when the river is up you can go all the way up to to Hunnington and a bit beyond which is near Ft. Wayne Indiana or on down to the Ohio.
http://www.wabashriver.us/access_points/index.htm
Vincennes is the nearest launch to the Wabash for the both of us, and if you consider Vincennes to be "0" on the miles, you can consider that to make the full run north would be approx. 200 miles. We're very well considering doing that with the pontoons next year. It would make the perfect "mother ship" to carry all the stuff necessary to make a really enjoyable run. Besides, as you can see by the map, there's several ramps and marinas along the way. So if need be, stuff can be had with out a great inconvenience.
We also talked about power. Making a run like that with a 1977 Johnson V-4 would be fine if I hauled a tanker behind it because it loves to drink the gas. I have in the past bought a couple of clapped out boats to salvage the mercruiser engines and alpha drives in case I needed them for future use for my 18 ft. Chris Craft. I know that the ratings are different and the 85 Sea Horse presently pushing the pontoon actually would have more torque than a 120 hp GM 3.0, but at the sacrifice of double the fuel consumption, if not higher. Besides, I'm more versed on working on an automotive style 4 cycle than a 2 stroke. And I think that eventually by force or by choice, the old 2
strokes are going to be fading out really fast in the near future, so may as well entertain the thought of doing a conversion this winter.
He said he has a friend who has a 28 ft. Harris who had his converted over a few years ago, and suggested I talk to him about his. He did tell me that a local welder has done a good job at converting several over to even putting 350 GM's in them! Besides his shop rate being very reasonable, he's well versed in steel and aluminum fabrication so that sounds like a good recommendation.
Then with the 3.0 GM I can outfit the charging system the way I want to power the options I want as well, instead of relying on the 10 amp stator 'battery maintainer' on the v-4.
Sometime next spring I still want to make the Ohio river run with the '23 Marquis, but this new thought is a sounding like it could become a great trip.
Anyhow, pardon all the blather, but my true question is to ask the members here if they have ever had an aluminum pontoon converted over from outboard to I/O?
Thanks!
Tim
SC's Forever!
Re: Converting 30' pontoon from 2cycle to 4 cyl mercruiser
Hi Tim!! Listen, just because you can't find anyone who has done this conversion before, don't let that stop you!!! You sound like a fellow who has thought this thing out carefully....don't hesitate to get EXPERT advice on things you are not familiar with...........
The one thing that comes to mind is to be aware of the weigh differential and distribution.....That old 85 is heavy(150lbs. +/-) but your I/O is probably 5/650lbs. at least.......
I'd go ahead, be careful, enjoy the build, and take PLENTY of pics for us to see
..Jim in Hammond, La.
Westport
Thanks for the reply, Jim. Yes, there is a much difference in weight, however I've got 30 feet of tubes for flotation. and I've seen 24 ft'rs with 350 GM's!
I'd like to go with a modern 4 cycle outboard, but my budget can't go that far.
I'm still kicking around the idea, and need to call some folk about the project. At the moment, I'm like a mosquito in a nudist camp. I know exactly what to do, but... don't really know where to start.
