Converting a 1995 Honda 45 to 50
Hi Guys
We have a 5m boat which we will be using for diving. It has a Honda 45hp on the back.
I have access to a similar boat with a Yamaha 50 on the back. The prop has been changed to help with carrying the load of divers and the package works really well.
I intend to change the prop as per the above to something like 11 5/8 x 11. However, I gather it is possible to uprate the 45hp to 50.
Please can anyone advise how this is done and ideally part numbers for any jets / carbs that I may need.
Thank you for your help.
Craig
IGIFF
Re: Converting a 1995 Honda 45 to 50
The carbs are different and the camshaft has a different porfile,this would be a costly job for the sake of 5 hp extra,let me know if you want to do it and I will send the part numbers
JB
Even if you were to do it all you would notice without a stopwatch, tach and GPS is a much lighter wallet. Even the stopwatch, tach and GPS might not be able to show any difference.
Sorry for not seeing your replies earlier.
Thank you for the advice. I haven't got the boat in the water yet, but it does sound like we'll have to put up with it or change the whole engine if need-be.
Fingers crossed!
Thank you again for the advice.
