bob johnson
- Feb 25, 2009
- 4,306
Well I think I have a need to retrofit one of my dual axle trailers into a single axle. I have a 22 ft starcraft holiday...it is being rebuilt, and I never owned it when it was complete, so I don't know its final weight...but am guessing that it might fall around 1300 lbs...add a 400 lb motor a pair od 60 lb batteries, 33 gallons of gas...maybe 100 lbs of misc gear after that...and I think the rig will weigh in about 2200 lbs... the trailer I bought for it is a 6800 lbs capacity... I think id beat the boat to death..
I have two other dual axle trailers that need work...but the springs I need to buy seem to only come in 1500 lb capacity( 23.5") four of those puts me at 6000 lbs!
one trailer was rbuilt with only one axle but it doesn't run good with the other springs hanging on for the ride...plus everything is rusty...so I am thinking of just taking that axle off and installing a 3700 lb TORSION axle...it will give me the low riding capacity I need for shallow boat launches, plus I don't have to buy springs or shackles or spring hangers..
so my question is just how to mount the torsion axle to the sliding-adjustable part of the trailer that the old springs attached to...
I am assuming the torsion axle just BOLTS straight up to the frame..but in this area there is the slider...do I just remove the slider??? it has about 4 sets of holes for adjusting the position of the axles.
plus ( I cant visualize one) is there any reason a single axle wouldn't work on this big long trailer ??? 25' long
bob
bob
