Re: Converting my i/o boat into a Outboard with a bracket
In building a bracket for two 150's you first have to take a good look at the strength of your transom that you now have .You can expect to invest 700.00 in parts if you do it right.Start off by buying 3 sheets 3/4 inch fir plywood (about 50 bucks a piece)not pressure treated plywood.You will be fiberglassing as you build.Start off with 2x2 aluim angle fastened to transom with 3/8 stainless steel bolts 8 inches on center ,very important at height with relation to keel of boat.Level the keel of boat ,level the plywood platform,keep it that way throughout job.Scribe platform to boat transom for tight fit and only fasten with a couple bolts as it will be taken down several times.You will need a router to put three 3/4 inch wide groove,(rabbit)(dado)to handle three partitions that will go from new transon to old transom.Always use 2x2 aluim angle inside were it makes sence.Use a 36 inch front to back platform,it's nice to have the room to check the engine.Rabbit ,dado the outside but don't worry about the tight fit as you will be getting the strength from the fiberglass but do use brass screws .I used a 12 degree angle for my yamaha 250 mounted on 1/2 inch high strength aluim bolted to plywood.Many frustrations but it all falls in place.Use the thick cloth on the bottom but do it while it's facing the sky. Bernie
