Converting normal jpg's to avatars?
WizeOne
I've notice several avatars that have obviously been created from user generated jpeg fotos. How is this done? I once tried to reduce a foto using Corel Draw, by simply reducing the dimension of the picture but the results were very distorted.
Bob_VT
Re: Converting normal jpg's to avatars?
Photobucket has the feature to re-size to an avatar. My avatar is a jpg of an explosion I did.
captquest
There are many free soft wares to customize your pics with. I like Picasa by Google. You can also just use Windows Paint to re size your pics quickly.
jay_merrill
Picasa is pretty hard to beat for free software. There is also a program called Gimp - its free, open source software and has extensive editing capabilities. Its a little "klunky" compared to Photoshop, but will do pretty much anything needed by even a pro photographer.
WizeOne
I looked around Photobucket and found no information to convert a pic to an avatar.
As I mentioned b4, I have tried to take normal jpegs, in programs like corel photo, and just reduce the pixel size. This alone does not do the job. It makes a very fuzzy picture. There must be some special techinique to reduce to avatar size and keep the clarity.
NelsonQ
I simply used a .JPG as the reference file for my avatar. Avatar resized itself.
Have you tried it?
WizeOne
Have you tried it?
You mean on iboats? If so that must be a new feature.
Plainsman
In photobucket, choose Edit>resize image> and make it 100x100
i386
Gottcha, Other reducing options I have tried just blur the picture.
That's because it's a "raster" image format. Jpeg is also a "lossy" compression method. Compression makes them take up much less space on your computer, camera, or whatever storage their own. The down side is that quality is reduced as compression is increased.
Think of a jpeg image as a grid of dots. (Actually, all raster formats are colors on a grid) To resize that image, a new grid has to be made. Then an approximation of which colors to put in each space on the grid has to be made. It is impossible to perfectly recreate the image on a different size grid. What works in your favor is to have the highest resolution image possible. That means there's more dots per inch in the grid. This is why it's important to keep the settings on your digital camera on the highest quality settings. Sure, your images might look the same on the screen, but when it comes time to print them or resize them there's a huge difference.
All tools that resize images are not created equal, but the image quality and resolution are key.
This doesn't answer your question, but you might be interested to know...
There's another type of image format called vector. Instead of using a grid of dots, it uses curves. Think of it as a set of mathmatical formulas to recreate the object. Vector images can be scaled infinitely larger or smaller without any loss in quality at all. Some examples of software that produces vector images would Adobe Illustrator and Corel Draw. Vector images are particularly suited to type faces and logos. Sign shops, print shops, and anyone who does graphic design and production works with these files every day. If you ever need a sign or cut vinyl letters made you will be ahead of the game if you give it to them in vector form. If you bring them a jpeg, they will just have to redo it and you will pay for the extra time involved.
