I have a merc 5.7 EFI bravo 2 setup that I am converting to closed cooling. I have purchased a San Juan block only system. Before I installed the system, my engine was running 175 on the temp gauge. I have found that the gauge is not working correctly. So I purchased a point and shoot temp gun and found that the temp was around 155 at idle. The problem that I am having is that now when I run the boat at 3,000 rpms the temp climbs up to 176. When I slow down to an idle, the temp goes back to 155. The thermostat is a 160 and I have been told by several people the engine should run at 160. Has anyone seen this problem before or have any ideas as to what I can do to fix it?
