Coolant for closed. System 5.0
rick3452
What is the recomended coolant for my 5.0. Should I add it through the pressure cap? When i look in there there is no visible fluid. Should there be
Thanks. Rick
Don S
Re: Coolant for closed. System 5.0
Drain some out of the block and find out which kind you have. You don't want to mix Propylene glycol with Ethylene glycol.
rick3452
Don. Through the blue. Valve under the manifold. And will i. Know by the color of the fluid. And lastly. Which is which
Thanks
Sorry for. Double post
Thanks
Yes, blue plug, 'n match the color of what you see....
Don S
I've seen green PG and EG antifreeze, so color doesn't really count unless you know the shades of green. You need two testers, the floating ball testers work great. Only one will work, the other won't. The one that works will tell you the type AF you have.
Personally, if it was my boat, and I didn't know what was in it, I would drain the the complete cooling system and fill it with what I wanted to use, and keep a 50/50 mix in a container on board for topping off.
