Cooling Question Johnson 9.9 1975
Tom Ross
I bought a used long shaft lower unit to replace my short shaft unit on my Johnson 9.9. When assembling the unit I noticed that there was no tubing running from the water pump to the copper tubing going to the motor head. This section was not included with the long shaft unit. What is the best way to handle this problem? Can I get some other tubing and attach it between the two points, or is there a replacement part available for this fix and if so what is it called and where can I find it:confused:?
ezeke
Re: Cooling Question Johnson 9.9 1975
That's a stock part #320025. Check the parts department at your local dealer.
