Hey folks. I picked up a boat on trade this week and it looks like it hasn;t been registered since 2003. I took the water pump hose off and the pump was full of rust. I then decided to remove the water pump to check for rust in the ports. The left side showed a little bit of rust around the opening but, nothing too bad. The right side port was clear. How can I tell if the engine cooling system is rusty? Also, how can it be fixed?
-Not sure if the internal water jackets are protected from rust from the factory? Is a marine 5.7 different than the 5.7 in my 1996 4x4 truck? Sorry for all the questions but, I want to check this out before I move forward in getting this engine a new water pump and fuel pump...
Thanks again,
Tonka
Thanks again,
Tonka
