Cooling system
putt4doe
I can't get water circulation on my 454 EFI and I have changed the impeller, thermostat and back flushed
alldodge
What is your serial number?
Are you trying muffs or is boat in the water?
alldodge
First check the hose connections.
Hose on top comes from drive
Hose on bottom goes to engine oil cooler and then to thermostat housing
If correct, disconnect hose at thermostat and start motor.
If no water, disconnect at cooler
If no water your back to the pump
putt4doe
I have done this including a back flush to assure that there is not blockage. So your are suspecting that it is the actual water pump? I am not sure your statement of the "start motor or cooler. This is not a closed system
alldodge
My comment was to remove the hose coming from the pump at the thermostat housing. The hose comes from the pump, to the oil cooler and then to the housing. Remove the hose and "start the motor" , you should see water coming out of the hose.
Since you back flushed including from the pump and out the drive, then it may be the pump. If it was started and did not have water it might have burnt the impeller.
Also look at the hose from the drive bell housing going to the transom plate on the stern. Some time that hose gets twisted and will not allow water to flow
