Copper Head Gasket
zsites
I took the head off of my 120 2.5L and it has a copper head gasket. It looked burnt between 2 cylinders. Does the replacement have to be copper or can it be some other material?
Howard Sterndrive
Re: Copper Head Gasket
head gaskets have come a long way in the last decade. A modern composite gasket with stainless steel fire rings would be available from Fel-Pro or other brands.
DianneB
If the original was copper, copper is by far the best replacement!
I have replaced copper with fibre (because it was cheaper and easier to get) and had to go back and replace the fibre with copper later. Would have saved myself a lot of work if I had just waited for the copper gasket.
Ayuh,... I really doubt it's the original,....
I've Never found a copper head gasket in a stock motor....
I feel ya can't go wrong with composite gaskets myself...
