core plug install
dvrdwn
Anybody have any experience removing and installing a core plug on a small outboard. Mines a 56 7.5 Johnson. They don't look like i expected either. They are like a little slug thats concaved.
jasper60103
Re: core plug install
Carefully punch a hole in the center and pry it out. Don't punch it too deep. I've also, used a self tapping screw and pried it out. This video (compliments of BktheKing) should be helpful. It's for a different carb, but shows how to remove and install core plugs...http://www.youtube.com/watch?v=DeN2cd-4MgU
dvrdwn
This is for a core plug on the cylinder head but watching the video they look the same. What do you guys think? Are they the same?
jasper60103
oohhhhh. Sorry, I have no idea. I'm sure others will chime in though.
dvrdwn
I have installed the plug. I hope I didn't over do it. The only thing I had available was a 1/4" bolt and I hope I didn't dent it in too far the other way. I'll let you know when I get time to test it.
F_R
The idea is to flatten it out. That expands it into the cavity. If you go beyond flat (dished the other way) it will get loose again.
dvrdwn
I bought 3 just in case. I will try It and let you know. Like they say 3rd times the charm.
