For my 1974 140 sterndrive, I purchased OEM #27-70974, which was foam rubber, but realized it is a bit different (as some have noted on this forum) from the one I need, which is 27-65373. So, I purchased the correct one, which is cork. I cannot find a rubber version. Before I got the correct cork gasket, I trimmed the rubber one to the point that it is a good, but not perfect fit. The cork gasket is a perfect fit.
I just have a tough time believing that a cork gasket is appropriate for the gimbal housing to transom. With either gasket, I intend to tack it on to the gimbal housing with bellows adhesive and seal it with 4200. Any opinions out there on cork gaskets?
