Correct orientation for Yamaha 2 stroke outboard fule filter
bvgas
I have an 8 hp yamaha 2 stroke outboard motor on which I'd like to change the fuel filter. The owner's manual seems to clearly show it with the arrow on it pointing away from the carbuerator and "out" towards the fuel line. (See attachement #1). On an exploded diagram from Yamaha & in a photo from a Yamaha service/dealer it shows it facing the other way. (See attachment #2 ) Which is correct? Thanks
rodbolt
Re: Correct orientation for Yamaha 2 stroke outboard fule filter
arrow indicates flow direction,should point to the carb direction.
bvgas
So just to confirm - the "Color Photo" from the Yamaha servicer which has the filter oriented with the arrow going toward the carbuerator - bringing fuel in from the "outside" would be the correct placement? The one in the actual Yamaha owner's manual is actually wrong. Thanks
rodbolt
yes,thats why the arrow is there. kinda like the arrow on your fuel primer bulb.
bvgas
Ok. Thank you. I appreciate the feedback.
