Correct Piston for 454 MAG Engine
JC766
Serial 0M005483, 1999 454 MAG
I have been searching for the correct stock specs but can't narrow it down. I need to have my block bored .030 over because of rust pitting. I would like to use aftermarket forged pistons and not pay the top dollar for a set of 8 OEM forged pistons.
I know the bore is 4.25 and I will need 4.28 pistons for a 4.0 storke.
But what is the rod length?
What is the dome height?
compression distance?
Top ring thickness?
I was told Chevorlet used JE Pistons in their MAG blocks but i cant figure out which ones. I looked at the Perprotech site but can't really igure it out form their specs either.
Can anyone help? I just want to match stock specs with a .030 bore. This is one of ICON's below.
Brand:ICON Performance Pistons Manufacturer's Part Number:IC783KTD-030
Part Type:Piston and Ring Kits
Product Line:ICON Premium Forged Piston and Ring Kits
Summit Racing Part Number:UEM-IC783KTD-030
Bore (in):4.280 in.
Bore (mm):108.712mm
Piston Style:Dome, with single valve relief
Piston Material:Forged aluminum
Compression Distance (in):1.395 in.
Dome Height (in):0.290 in.
Piston Head Volume (cc):-27.00cc
Wrist Pin Style:press-fit or floating
Pin Diameter (in):0.990 in.
Gapless:No
File Fit:Yes
Top Ring Thickness:1/16 in.
Top Ring Material:Ductile iron
Top Ring Facing Material:plasma-moly
Second Ring Thickness:1/16 in.
Second Ring Material:Iron
Second Ring Facing Material:Cast iron
Oil Ring Thickness:3/16 in.
Oil Ring Material:Stainless steel
Oil Ring Tension:Standard
Quantity:Sold as a kit.
Notes:Closed chamber cylinder heads. Hollow dome design. Spacer ring included.
