Correct prop - 16' 140hp I/O?
Munny
I have a Four Winns 16' with a 140hp Merc I/O. Right now I am running a 14.5 17p 3 blade aluminum prop.
I have 2 other props that are 17p but 14.75, and 15" diameters.
I am looking for the right pitch-diameter for tubing, and skiing.
What RPM range should I be trying to achieve at WOT?
Any suggestions?
Munny
Re: Correct prop - 16' 140hp I/O?
[UPDATE]
With the 14.5" 17p prop my RPM's topped at 4100ish, 33MPH (about 3/4 of weight limit). It seems to get on plane after 7 seconds, or so. I am wondering if I am trying to turn to big of a prop, and/or possibly the wrong pitch? Shouldn't this boat be running near the 5k RPM range and able to hit 40mph?
Any suggestions here greatly appreciated.
Ayuh,..... 4600rpms is her Sweet Spot,.....
You migh want to try a 15" pitch....
