have pontoon and the prop is only 3-4 inches in the water is this deep enough?
K kelley146 Recruit Joined Jul 29, 2007 Messages 1 Jul 29, 2007 #1 have pontoon and the prop is only 3-4 inches in the water is this deep enough?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,251 Jul 30, 2007 #2 Re: correct prop depth This question would be Much Easier to Answer if you'd supply info, Such as,..... What is the Boat,..... What is the Motor,..... Is that 3,or 4"s from the very Top of the prop,..??....
Silvertip Supreme Mariner Joined Sep 22, 2003 Messages 28,771 Jul 30, 2007 #3 Re: correct prop depth Short shaft motor perhaps on a 'toon that requires a long shaft motor?
Texasmark Supreme Mariner Joined Dec 20, 2005 Messages 14,802 Aug 1, 2007 #4 Re: correct prop depth You tell us. Does the prop ventilate when you hammer the throttle, or when you are in rough water. If no, answer is no. If yes, answer is yes. If yes, then what are your options to correct it would be your next question for the guys to answer. Mark
