Correct prop size
Jen&tom
I have a 2005 2502 trophy with 275 verado looking for correct prop came with 4 blade revolution 15 pitch can’t go over 26 at 6000
Please help
first, welcome aboard
second, please have all 6 answers to the questions in the sticky labeled "Read this first"
you most likely have a spun prop.
Jen&tom
I have an 05 2502 trophy.the prop I have now is 15” 15 pitch on a merc 275 verado , comes up on plane quickly but top speed is only 26 knots at wot 6200 .I’ve read same boat cruising at 30 knots at 4700 rpm trying to find correct prop mine is stainless merc revolution
dingbat
Prop calculator comes up with 39% slip using the figures you posted.
4700 at 30 kts is more inline with performance from a 17" prop
QBhoy
Please help
Are you probably under pitched and hitting the limiter there, I’d say.
Capt. Lenny
Prop selection is more of trial and error than it is science on paper. Buy used props in good condition and resell them if they don't do what you want and buy another. I have probably bought 10 props for my current motor setup and some I like and some I don't. I'm always looking for that silver bullet that will give me the best holeshot and best top end. There's no perfect combination. I sure would like to try a 14.6 X 15 Revolution 4 but can't find one at a reasonable price so I'll just wait.
What does your issue have to do with the OP's thread?
the 6 questions in the sticky at the top of the forum take the trial and error out of the prop selection. Additionaly with a single gear, you can never get the best holeshot and the best top end with a single prop.
